New Firmware for Zumo XT
simoncrewe
Has liked: 47 times
Been liked: 38 times
Post by simoncrewe »
Firmware version 6.4 has just been released.
Re: New Firmware for Zumo XT
simoncrewe wrote: Thu Apr 14, 2022 5:35 pm Firmware version 6.4 has just been released.
Been brave enough to update your XT to it?
Grispoil
Post by Grispoil »
I have updated mine from 6.30, it installed properly.
Did it fix or break anything? Time will tell.
raza
Has liked: 25 times
Been liked: 15 times
Slovenia
Post by raza »
New update with a new bug in the program!
In the map view, click on the lower right corner (three vertical dots) - the device freezes and resets!
Who else is this happening to?
jskene
Post by jskene »
I just updated my XT and everything seems to be working properly, including the three dots in the lower right corner in map mode.
The first thing I did was to disable the helmet law notification!
Grispoil
Post by Grispoil »
raza wrote: Thu Apr 14, 2022 9:19 pm New update with a new bug in the program!
Yes, I had the same problem. I resolved it by performing a reset and installing the additional updates that came up shortly after.
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
Grispoil wrote: Fri Apr 15, 2022 4:34 am Yes, I had the same problem. I resolved it by performing a reset and installing the additional updates that came up shortly after.
What are these additional updates?
Thanks
Anyway my file size is " 69 MB" ,no 72,48 MB.The file sizes are different and they depend on where you live? ( I live in Italy)
giuseppe66
Has liked: 30 times
Been liked: 9 times
Italy
Post by giuseppe66 »
Raf wrote: Fri Apr 15, 2022 8:01 am
Thanks
Ufficialmente sono tre come indicato. Non ufficialmente lo scopriremo sulla strada..speriamo abbiano ripristinato almeno le smart notification con android 12..
colirv
Has liked: 66 times
Been liked: 64 times
Post by colirv »
Well I had to downgrade from 6.3 to 6.2. I'll hang on and see what people make of 6.4!
Colin
BMW R1250RS
https://www.namrider.com
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
Ok! Then I prefer not to update..
@giuseppe66
Io ho disattivato le notifiche . Molti problemi. ( I have turned off notifications. A lot of problems)
