Hi Guys
Is there a way to ease all routes and waypoint from my XT without doing a full factory reset.
Thanks in advance
Del
Erasing Data
- simoncrewe
- Has liked: 47 times
- Been liked: 38 times
Re: Erasing Data
Personally I would delete everything via Garmin Explore and then re - synch the XT with Explore.
- Has liked: 140 times
- Been liked: 437 times
Re: Erasing Data
If you don't use Explore...
For deleting routes: Go into Trip Planner > Saved Trips the tap the spanner icon (Wrench). The resulting menu contains an option to delete trips. There will then be the option to select all or individual trips.
For saved waypoints: Go into Where To? > Saved (or Favourites), tap the hamburger icon, the "Delete Saved Places".
Any routes stored on an SD card must be deleted manually using a file explorer while connected to a computer.
Re: Erasing Data
Or while you be connected to Basecamp...
Bye, Robert
