Peobody wrote: ↑Sat Jul 16, 2022 1:41 pm
Time and distance calculation differences between devices doesn't surprise me. Time differences are common between Basecamp and the XT even when the XT is showing the same route and using the same map. I have never paid attention to distance.
Don't forget that when the route recalculates, as well as any avoidances that are set, the XT ( and the earlier units) use the 'rider profile' which is created according to the roads that you ride and the type of roads and the speeds that you typically ride. People will have built up different info in their profiles.
I don't know how it uses the data or where it is stored, but some of the data about roads ridden in the past can be viewed in the hidden Diagnostic Page (long press the circular speedo) -> Developer Info -> My Trends Info.
Certainly riding locally I never take the busy main roads. Eventually, the XT realises this and it starts to route me on the roads that I normally take. I've reset my XT too many times to have built up a long term profile, so I don't know how that affects the choice of roads seldom ridden.
Use Basecamp (mainly), MyRouteApp (sometimes)
Links:
Zumo 590/5 & BC . . .
Zumo XT & BC
