Imported Trips Not in Sequential Order
PaulaRay
Has liked: 74 times
Been liked: 10 times
Post by PaulaRay »
I have several routes listed on my 595LM under Imported Trips that I would like to change the order they're in manually as well as sequential. Is that possible? Thanks
Les
Has liked: 8 times
Been liked: 19 times
Re: Imported Trips Not in Sequential Order
Post by Les »
I usually number my trips to put them in order.
PaulaRay
Has liked: 74 times
Post by PaulaRay »
Thanks for the help..... I number mine as well but, the order is all mixed up. I can't figure out how to move them into ascending order. Thanks again.
Has liked: 110 times
Been liked: 70 times
They might be sorted by date / time of the start of the trip in your 590.
Has liked: 108 times
Been liked: 99 times
PaulaRay wrote: Sun Oct 09, 2022 10:33 am Thanks for the help..... I number mine as well but, the order is all mixed up. I can't figure out how to move them into ascending order. Thanks again.
They get sorted by route name, not file name, at least on my 660. So the trick is to go in and put numbers in the actual route name in the GPX file. Only takes a minute or two using a plain text editor. Look for the following tags in the GPX file: <rte> then <name>. Like this:
<rte>
<name>1.Catskills Shawangunks Ride</name>
PaulaRay
Has liked: 74 times
Post by PaulaRay »
Thanks Danham, I will give that a try.... Hopefully that will do the trick. I'll report back once I get to it. Thanks again, appreciate it.
PaulaRay
Has liked: 74 times
Post by PaulaRay »
Oop North John wrote: Sun Oct 09, 2022 12:26 pm They might be sorted by date / time of the start of the trip in your 590.
Thanks for the help...... I jump in and try in the GPX file like danham stated. Thanks again.
