So in lieu of being able to connect my XT to my laptop, i started playing with Garmin Explore.
It's a bit odd, but it works. Imported 14 routes.
All routes sync'ed to Zumo XT
But the last 7 routes are stuck in an error telling me the route is currently being converted for use with the zumo XT devide.
First 7 converted quickly. Last 7 are stuck
Is there a limit of routes that can be processed at one time with Explore?
Thanks!
Zumo XT and Garmin Explorer
- Has liked: 110 times
- Been liked: 253 times
Re: Zumo XT and Garmin Explorer
If I had an SD card slot in my computer, or get an SD-USB adapter I'd say screw Explorer altogether and put everything on the card.
