End of life, no more map updates for 660/665?
Re: End of life, no more map updates for 660/665?
That is what I want to know. Right now, can anyone get 665 to update new maps. Some had latest maps, but I don't think they did it since I posted threads. The 660 is still listed as updates available but 665 is not. Be sure to come back and tell us how it goes.
- Has liked: 29 times
- Been liked: 39 times
I will update my 665 in a couple of days after I get the 660 maps up and verified. Well report back.
Updated to add. and yes Garmin Express says the updates are available fro my 665 and my 550. The only reason I don't update the 550 is that they made the street names upper and lower case and it appears the 550 only supports upper case letters.
As noted above, the only reason I have not updated the 665 is that it is my go-to GPS for travel. It works now so....
