XT2 rebooting
Re: XT2 rebooting
Yes, last 2 weeks is rebooting a lot. It is solved by disconnecting the Tread. It's some problem with the latest Tread update. If you don´t use the track recorder, and if you don´t create new waypoints without name (default wp), always with a new name and icon, looks working well.
As someone on the forum already said, one step forward and two steps back.
