Zumo 340 LM Map Update issue
For everything Garmin Zumo 345/350 related
Locked
Batmancaver
Wales
Post by Batmancaver »
Hi,
I hope somebody here can help with an issue.
I'm aware Garmin is stating that there will no longer be updates for this series but when I connected my Zumo to my MAC at the weekend Garmin Express stated that there were updates to install so I let it do it's business.
Well afterwards it appears to have updated the wrong map and I've now lost decent quality maps of (at least) the United Kingdom. It has also set the country to Turkey??? I've tried to change the country but the keyboard letters for the UK are not selectable!
I've checked the installed map and my Zumo now has the following map installed: 'CN Europe NTU 2025.20 ALL South'.
I'm guessing that for some reason it has installed the southern Europe map version instead of the north Europe version!
Does anyone have any idea how this can be rectified and the correct map installed?
If it's not possible through Express to install the correct maps then I believe that you can install other maps (e.g. OSM) to fulfill my requirements.
If that is the case then could somebody provide a link to some easy instructions that tell you how to do that please?
Thanks for any help, it will be much appreciated :-)
Has liked: 341 times
Been liked: 368 times
Re: Zumo 340 LM Map Update issue
You should be able to run Express and select the option to change the map. Try that first and post again when you have.
Locked
