Garmin Express 7.24.0 has been released
turbo19
Has liked: 101 times
Been liked: 24 times
Andorra
Re: Garmin Express 7.24.0 has been released
Post by turbo19 »
Garmin has told me that from now on there will no longer be that option. They seem to want to separate Basecamp from XT2/Tread forever. It's a shame. :cry:
electro_handyman
Been liked: 37 times
Post by electro_handyman »
I don't know if it is still the same in 7.24, but the last release of 7.23 would ONLY install the map to the computer AFTER it was installed in the XT 1st.
twowheelstom
Has liked: 114 times
Been liked: 40 times
Post by twowheelstom »
a week ago i ran Express 7.24.0 and it updated new 2025.20 CN NA maps to the XT first, then after that was completed, I downloaded 2025.20 NA maps to my PC computer, updating maps on device and computer is a completely separate process now, the older Express used to have a button to update device & computer all at the same time, but that option is not available anymore, you have to do computer and device updates separately now. 8-)
Has liked: 148 times
Been liked: 455 times
It sounds like 7.24.0 is detecting a connected XT2 and not offering the install map to computer option. I don't see any logic in this. If the want to totally stop supporting Basecamp then why not remove it for all devices. If they want to discourage XT owners from upgrading to an XT2, well they're on the right path.
Treve
Been liked: 3 times
Sweden
Post by Treve »
Hi twowheelstom
I cant find the option to separate load maps from XT2 to PC/BC in GExpress 7.24.00. I have tried twice without locate this option. Grateful for education if I am wrong. I downgrade GExpress to the old 7.23.00 and it works again.
Treve wrote: Mon Feb 03, 2025 8:28 pm I cant find the option to separate load maps from XT2 to PC/BC in GExpress 7.24.00. I have tried twice without locate this option. Grateful for education if I am wrong. I downgrade GExpress to the old 7.23.00 and it works again.
Based on everything I have seen, Garmin Express 7,24.00 does not have the "Install to PC" option when an XT2 is connected. I am curious to see if anyone knows of any options other than sticking with Garmin Express 7.23.
Has liked: 131 times
Been liked: 108 times
Peobody wrote: Mon Feb 03, 2025 10:19 pm Based on everything I have seen, Garmin Express 7,24.00 does not have the "Install to PC" option when an XT2 is connected. I am curious to see if anyone knows of any options other than sticking with Garmin Express 7.23.
By using a pre XT2 GPS that has the same mapping, for example a 590 / 595 or XT.
dhwalt
Post by dhwalt »
XT2 with Garmin Express 7.23.0.0 vs 7.24.0.0
Found this thread after spending a lot of time trying to install map updates to a computer. Same as various people have found that the XT2+GE 7.24.0.0 appears to have lost the install to computer option when using Basecamp and it is GE 7.23.0.0 only.
turbo19
Andorra
Post by turbo19 »
Where can I find 7.23.0.0 G.E. version? Thanks ;)
turbo19 wrote: Mon Feb 10, 2025 5:57 pm Where can I find 7.23.0.0 G.E. version? Thanks ;)
I got it from here:
https://www.filepuma.com/download/garmi ... /download/
