can 595 firmware be loaded on a 590 ?
oldwobbler
Has liked: 9 times
Been liked: 6 times
Re: can 595 firmware be loaded on a 590 ?
Post by oldwobbler »
Thanks for the help John, lkraus, that has worked fine. I now have two units running the 595 version.
Has liked: 378 times
Been liked: 819 times
oldwobbler wrote: Sun Dec 08, 2024 9:28 pm Thanks for the help John, lkraus, that has worked fine. I now have two units running the 595 version.
Well done ! It is quite daunting the first time that you do it, isn't it ? Make sure you know which one was the original 590 - in case you ever wish to restore it - because you cannot use this procedure to change an original 595 to a 590.
Just curious - Do you have the option to change the screen orientation on your 590 that is now a 595 ?
