No satellite reception in new house.
colirv
Has liked: 61 times
Been liked: 59 times
Re: No satellite reception in new house.
Post by colirv »
Peobody wrote: Sat Jan 18, 2025 1:34 pm so I finally created an instructional text file.
Which, of course, you're planning on sharing!
Colin
BMW R1250RS
https://www.namrider.com
Has liked: 70 times
Been liked: 191 times
Has liked: 129 times
Been liked: 102 times
Mzokk wrote: Sat Jan 18, 2025 1:06 pm You can also tell your unit that you are in a different location in simulator mode. Handy if you are designing routes on another continent and you are using OSM maps or such.
I know of that feature. I got tired of researching (or being lazy and just asking) how to do it so I finally created an instructional text file.
From the on-line manual:
https://www8.garmin.com/manuals/webhelp ... D6D88.html
Has liked: 145 times
Been liked: 451 times
colirv wrote: Sat Jan 18, 2025 2:57 pm Which, of course, you're planning on sharing!
Here you go. I'm sure it's not original though. I apologize for not crediting the original source.
Setting a Simulated Location
If you are indoors or not receiving satellite signals, you can use
the GPS simulator to plan routes from a simulated location.
1 Select Settings > Navigation > GPS Simulator.
2 From the main menu, select View Map.
3 Tap the map twice to select an area. This zooms in the map.
4 Long press on the spot where you want to set the vehicle location.
The address of the location appears at the bottom of the screen.
5 Tap the location description.
6 Scroll down on the left of the resulting screen until you can tap on "Set Location".
