Introducing TripManager
Re: Introducing TripManager
HarryMJ wrote: Sat Feb 08, 2025 4:57 pm TripManager is amazing...
Agreed. I have been bugging @FrankB with every program niggle and behavior change preference that I encounter so this statement made wonder if I have expressed it strongly enough to Frank. I hope I have Frank.
HarryMJ wrote: Sat Feb 08, 2025 4:57 pm Thank you for that... so TripManager do not like the Danish characters :oops: .
I will make TripManager love Danish characters!
Peobody wrote: Sat Feb 08, 2025 5:44 pm
Agreed.
These are the replies that make it worthwile for me.
HarryMJ
Has liked: 6 times
Been liked: 3 times
Denmark
Post by HarryMJ »
FrankB wrote: Sat Feb 08, 2025 6:48 pm
Ha-ha, thank you :-)
I changed the Danish character in TourStart, exported from TourStart, but did still not work, but then removed following
Code: Select all
<![CDATA[ ]]>
from the line below
Code: Select all
<name><![CDATA[Tur 01 Stevns fyr fra Nivaa]]></name>
..and then it just works when using TripManager to import the route to my XT..
I would say, the problem is TourStart, not TripManager
Brgds. Harry
Brgds. Harry
Zumo XT
Route planning in QmapShack / TourStart / CaliMoto / BaseCamp / TripManager
Honda NC700 XA
@HarryMJ
A little background regarding CDATA.
CDATA is needed when the data (in this case the tripname) contains XML characters. Think of < > & or "". LT GT Ampersand Double quote. It is definitely not needed for Danish characters!
On the other hand it is NOT invalid to use CDATA, just unneeded and unexpected. Here is an url that probably explains it better. http://xml.silmaril.ie/cdata.html
Your remark about being CDATA the culprit and not the "A with circle" is correct. I had hoped that by not using that, Tourstart would not generate the CDATA, that's why I mentioned it.
Now, what's next?
- You say a bug in TourStart. I'm not sure. Even more unsure if they will fix it.
- I did some debugging and I'm quite sure I can fix it in TripManager. That will likely be the fastest. Agree?
Frank
HarryMJ
Has liked: 6 times
Been liked: 3 times
Denmark
Post by HarryMJ »
Hi Frank
FrankB wrote: Sat Feb 08, 2025 7:41 pm @HarryMJ
Now, what's next?
Frank
Thank you for the explanation... I think you are right regarding TourStart, it is a 1-2 guys company here in Denmark.
- I agree, you will most likely be faster with a solution :-)
Just let me know if and when you will need some test feedback.
Brgds. Harry
Brgds. Harry
Zumo XT
Honda NC700 XA
HarryMJ wrote: Sat Feb 08, 2025 9:57 pm Just let me know if and when you will need some test feedback.
Here you go. Version V1.2.0.123 should fix it.
https://github.com/FrankBijnen/TripManager/releases/
@Peobody
Also excluded way points from stripped routes.
HarryMJ wrote: Sat Feb 08, 2025 9:57 pm I think you are right regarding TourStart, it is a 1-2 guys company here in Denmark.
I had a look at the site. Looks 'Scandinavian oriented' to me. Can you use it practically when you're not a 'pro user'? (We from Holland dont like to pay!)
@FrankB , is there any reason (recommendation?) to uninstall a previous version before installing a new one?
No. Everything gets overwrtten.
