Basecamp a bit clunky
Has liked: 414 times
Been liked: 229 times
Re: Basecamp a bit clunky
CollingsBob wrote: Thu Jan 23, 2020 6:14 pm
Stu wrote: Wed Jan 22, 2020 1:29 pm Anyone tried ITN converter? http://www.benichou-software.com/index. ... =3&lang=en
I used it when I had a tom tom
I found the maps smoother than basecamp and adding waypoints to for the route just makes them shaping points but you still have to import it to basecamp to check which isn't a problem
Can ITN converter be used to convert a route created in Garmin Basecamp to Google maps?... I installed it but it wont import a .gdb file..
There is some issues with Google maps! They have changed their API terms and put priced a lot of people! As a result Google maps no longer works with ITN converter and a whole host of services!
titter
Has liked: 8 times
Post by titter »
sussamb wrote: Mon Jan 20, 2020 11:39 am Me too. I'll stick with 4.6.2 until they restore the GE link
I'm running version 4.7.1. I've found a link to download the older version, you suggesting I should download and use that if I want to use it in conjunction with Google Maps?
Iris
Been liked: 12 times
Post by Iris »
Yes. The 4.6.2 works with google earth.
CollingsBob
Has liked: 144 times
Been liked: 21 times
Post by CollingsBob »
Iris wrote: Fri Jan 24, 2020 3:13 am Yes. The 4.6.2 works with google earth.
Have you got a link to 4.6.2?
Certified JB Welder
Has liked: 343 times
Been liked: 368 times
titter
Has liked: 8 times
Post by titter »
CollingsBob wrote: Fri Jan 24, 2020 4:31 am
https://www.technoleros.com/download/ga ... amp-4-6-2/
