Routing on the PC
robbo12
Routing on the PC
Post by robbo12 »
When I Make a route on the PC (Windows 10) the calaulacted route is not on the road but parallel to it. This is something new Basecamp 2020.2 used to show the route correctly. any suggestions?
Robbo12
kernowing
Has liked: 133 times
Been liked: 61 times
Re: Routing on the PC
Post by kernowing »
If you select "Maps" in the task bar, what's showing the check mark?
2007 GL1800 Goldwing
Zumo 660LM
Has liked: 373 times
Been liked: 383 times
This often happens if you've accidentally rotated the map. Select the compass icon and rotate it so it points north, that should resolve it.
Breezly
Has liked: 22 times
Been liked: 32 times
Post by Breezly »
What sussamb said. Or Use the pull down menu: View / Align North Up.
I seem to do this more frequently than I like when I'm using the track pad on my laptop instead of a mouse.
robbo12
Post by robbo12 »
Thank's that solved the problem.
Robbo12
Great :)
