Basecamp 4.7.2 and Zumo XT
Grispoil
Post by Grispoil »
Hello experts,
I am at still using basecamp 4.6.2 (because of google earth) and I have a Zumo XT and I have just noticed the following change notification:
Changes made from version 4.7.1 to 4.7.2:
-Fixed routing mismatch issue on Zumo XT <<<<<<<<<<<<<<<<<<<<
-Fixed map display issue on Zumo XT <<<<<<<<<<<<<<<<<<<<<
-Re-enabling Yelp searching
-Various stability and bug fixes
-FourSquare and Parkopedia products will now be displayed in BaseCamp as pre-loaded maps on specific devices
Does anyone know what the basecamp fixes are in relation to the Zumo XT exactly? Maybe I do not need them...
I do not want to upgrade to 4.7.2 unless I absolutely have to...
Thanks for any info you can provide.
Yvan
Has liked: 343 times
Been liked: 368 times
Re: Basecamp 4.7.2 and Zumo XT
I'd try and see it you're happy with 4.6.2 first.
