590 Rubber Power Button Failed
Re: 590 Rubber Power Button Failed
You can contact me ; zumo@ziggo.nl
- 4C5DB02C-4853-49F7-AA9E-F26494FC718A.jpeg (161.89 KiB) Viewed 7200 times
- AC35D038-726E-4998-AD96-9C88785399C5.jpeg (142.23 KiB) Viewed 7366 times
Hi, tried to contact you via email provided, but no response. Are you still able to help with failed zumo power button?Yohammer wrote: Tue Mar 28, 2023 12:51 pm You can contact me ; zumo@ziggo.nl
roadking321
is the rubber cover over the button & power/charging glued down or is mine stuck to the plastic due to wear/heat, etc? Also I was able to remove 9 hex screws plus the phillips holding the cover for the power plug but what type of heads are the 4 screws around the battery under that cover?
thanks!!!
thanks!!!
biz
- Has liked: 25 times
- Been liked: 25 times
The little rubber "door" over the USB port is held on with one screw, as you've discovered. Rest of the cover is stuck on with some sort of glue/black silicone/whatever. If you're replacing it, you just need to pick it off bit by bit. As far as I remember there are no screws under it, if that's what you are looking for. The 4 screws in the battery compartment are Torx. I don't know what size, other than they are smaller than T5.
roadking321
Ok it sounds like the rubber pad will get destroyed taking off. I bought a set of all types of very small precision “screwdriver set” starting w T1-T20 but none seem to fit. None of my “camera repair” kit tools work either.
BTW, Do you sell or know where to buy those rubber pads?
Thanks, Paul
Thanks, Paul
- Has liked: 119 times
- Been liked: 267 times
I decided not to mess with mine earlier this yr since I could find a replacement pad. I sent mine to https://www.palmdr.com/
biz
Yes, the rubber pad is destroyed when removing - only way to do it, paul. Hmmm.... maybe the tiny screws aren't Torx after all then - they looked like they were to me, but .....roadking321 wrote: Tue Sep 23, 2025 7:21 pm Ok it sounds like the rubber pad will get destroyed taking off. I bought a set of all types of very small precision “screwdriver set” starting w T1-T20 but none seem to fit. None of my “camera repair” kit tools work either.
Thanks, Paul
The rubber pad for mine I got from the guy mentioned earlier in the thread. He's in Holland. Pad from him was absolutely perfect, and easy to fit. Try emailing him on hanshamer@ziggo.nl.
You can also buy a half-sized part of the pad, but a little harder to make fit perfectly:
https://www.ebay.co.uk/sch/i.html?_nkw= ... m570.l1313
Or just the button (easy fix, but not 100% convince it's waterproof):
Jim
roadking321
OK, thanks for the info but if I gotta send for that half pad or button to Europe, I think I'll do without it - or just plug the hole & let it turn on when its connected to power. Obviously with no parts available thru Garmin or otherwise, they prefer to sell a new GPS. Thanks again
biz
There are some sellers in the US too:roadking321 wrote: Wed Sep 24, 2025 11:14 pm OK, thanks for the info but if I gotta send for that half pad or button to Europe, I think I'll do without it - or just plug the hole & let it turn on when its connected to power. Obviously with no parts available thru Garmin or otherwise, they prefer to sell a new GPS. Thanks again
https://www.ebay.com/sch/i.html?_nkw=12 ... m570.l1313
https://www.ebay.com/sch/i.html?_nkw=16 ... m570.l1313
