Page 2 of 3
Re: 590 Rubber Power Button Failed
Posted: Tue Mar 28, 2023 12:51 pm
by Yohammer
You can contact me ;
zumo@ziggo.nl
- A16E4AF1-962C-4CF0-B75E-2392B271F58B.jpeg (153.87 KiB) Viewed 7372 times
Posted: Fri May 12, 2023 9:46 am
by biz
Just to say I got one of Yohammer's replacements and fitted it. Not a difficult job, and solves the problem.
Posted: Fri Oct 06, 2023 3:19 pm
by diamondba
Yohammer wrote: Tue Mar 28, 2023 12:51 pm
zumo@ziggo.nl
Hi, tried to contact you via email provided, but no response. Are you still able to help with failed zumo power button?
Posted: Mon Sep 22, 2025 4:20 pm
by roadking321
is the rubber cover over the button & power/charging glued down or is mine stuck to the plastic due to wear/heat, etc? Also I was able to remove 9 hex screws plus the phillips holding the cover for the power plug but what type of heads are the 4 screws around the battery under that cover?
thanks!!!
Posted: Tue Sep 23, 2025 10:00 am
by biz
The little rubber "door" over the USB port is held on with one screw, as you've discovered. Rest of the cover is stuck on with some sort of glue/black silicone/whatever. If you're replacing it, you just need to pick it off bit by bit. As far as I remember there are no screws under it, if that's what you are looking for. The 4 screws in the battery compartment are Torx. I don't know what size, other than they are smaller than T5.
Posted: Tue Sep 23, 2025 7:21 pm
by roadking321
Ok it sounds like the rubber pad will get destroyed taking off. I bought a set of all types of very small precision “screwdriver set” starting w T1-T20 but none seem to fit. None of my “camera repair” kit tools work either.
BTW, Do you sell or know where to buy those rubber pads?
Thanks, Paul
Posted: Tue Sep 23, 2025 9:20 pm
by rbentnail
I decided not to mess with mine earlier this yr since I could find a replacement pad. I sent mine to
https://www.palmdr.com/
Posted: Wed Sep 24, 2025 9:53 am
by biz
roadking321 wrote: Tue Sep 23, 2025 7:21 pm
Thanks, Paul
Yes, the rubber pad is destroyed when removing - only way to do it, paul. Hmmm.... maybe the tiny screws aren't Torx after all then - they looked like they were to me, but .....
The rubber pad for mine I got from the guy mentioned earlier in the thread. He's in Holland. Pad from him was absolutely perfect, and easy to fit. Try emailing him on
hanshamer@ziggo.nl.
You can also buy a half-sized part of the pad, but a little harder to make fit perfectly:
https://www.ebay.co.uk/sch/i.html?_nkw= ... m570.l1313
Or just the button (easy fix, but not 100% convince it's waterproof):
Jim
Posted: Wed Sep 24, 2025 11:14 pm
by roadking321
OK, thanks for the info but if I gotta send for that half pad or button to Europe, I think I'll do without it - or just plug the hole & let it turn on when its connected to power. Obviously with no parts available thru Garmin or otherwise, they prefer to sell a new GPS. Thanks again
Posted: Thu Sep 25, 2025 10:07 am
by biz
roadking321 wrote: Wed Sep 24, 2025 11:14 pm
There are some sellers in the US too:
https://www.ebay.com/sch/i.html?_nkw=12 ... m570.l1313
https://www.ebay.com/sch/i.html?_nkw=16 ... m570.l1313
