Re: My xt Does not charge..;
Posted: Tue Oct 04, 2022 3:34 pm
I left my XT on my bike for approximately 4 months. Not sure why it drained to the point of no return as the 12V supply is switched. I noticed this morning when I started the bike for the first time it didn’t power on, even after a few minutes with the engine running. I checked the holder voltage and it was good.
I then tried to charge it via a wall charger in the house where I can see the Current. It was trying to boot up but indicating 0.4A then it would shut off and show 0A. I kinda knew from experience the battery was drained beyond what the motherboard would tolerate for its boot process and charge. I find it strange the unit will not power up if the battery is goosed. I had a 595 previously and correct me if I’m wrong but I think that would boot up without a battery?!?
Anyway I took the screen off and disconnected the battery connector. The battery still had approx 2.3V so still recoverable. If the voltage drops way below its nominal 3.7V, say below 1Volt I would say it might be too far gone, maybe not. I’m just guessing here but the workable voltage range of the XT Battery is probably between 3.5 -3.7 Volts ie 0-100%. Anything below this is considered drained. The charging circuit probably shuts the unit down before this to protect the battery from draining excessively.
Morale of the story try and avoid your XT from lying around with a drained battery for extended periods.I think my issue was leaving the XT on the bike connected to the charger/holder and some parasitic battery drain occurred.
The good news is my XT seems to be fine now. Also the battery and screen replacement would appear to be pretty straight forward if you need to do that. One important point to remember is be extremely careful when disconnecting the Screens ribbon cable connector. If you break the black flip up part it’s literally game over for your GPS, I know this as it happened to myself years ago with an old Montana. The connector was brittle after years of use and it broke when I tried to lift it up. I remember trying to source the connector and failed miserably.
