Already tried that. It just opens up the weather forecast page in Fahrenheit.Oop North John wrote: Mon Jan 31, 2022 8:47 pmThe Zumo XT uses drive, see this page in the manual and select the temperature icon link: https://www8.garmin.com/manuals/webhelp ... A2CA0.htmlFxwheels wrote: Mon Jan 31, 2022 7:15 pm I'm not sure what Drive app you're talking about. Garmin connects to a smartphone via Smartphone Link app which is just a bare link to your phone. The temperature itself is coming to the nav from what you use on your phone (same way as the txt msges, traffic...).
Smartphone link is for older Garmin GPS's: https://play.google.com/store/apps/deta ... n_GB&gl=US
Temperature units
Zumouser34
- Been liked: 1 time
Re: Temperature units
Zumouser34
It’s quite frustrating! No reply from Garmin yet.Stu wrote: Mon Jan 31, 2022 9:07 pm I have just gone on mine to try and find the answer and I cannot see any settings whatsoever on drive or the XT
Changing from miles to KM didn't alter it either
Mine is set to mines and the temp shows Celsius not sure where it gets that info from!
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
I think your locale is set wrong
https://support.garmin.com/en-GB/?faq=J ... qnnv8wwip8
The unit of temperature displayed on your device will depend on the temperature scale used by the Country your device is set to. You have the option to set the device to a different locale in order to change the temperature scale between Fahrenheit and Celsius.
You can change the locale without a full restore
On my XT there seems to be a global setting adjustment for either metric or imperial measurements.
Miles/km can be selected in Settings/Units & Time/Units. I do not need to change the country setting. I can pick either miles or km, If I pick miles I get F for temp. If I pick km I get C for temp.
If that's true than it's lame. I'm in the US and can use C or F (and independently of mi/km setting). But the XT is depending on a locale?? In other words for Europe locations it'll say C and in the US - F? Hmm, DunoStu wrote: Mon Jan 31, 2022 9:34 pm I think your locale is set wrong
- Site Admin
Blame the Americans! they created it! Oh hang onFxwheels wrote: Mon Jan 31, 2022 9:43 pmIf that's true than it's lame. I'm in the US and can use C or F (and independently of mi/km setting). But the XT is depending on a locale?? In other words for Europe locations it'll say C and in the US - F? Hmm, DunoStu wrote: Mon Jan 31, 2022 9:34 pm I think your locale is set wrong
I agree if thats the case its a bit crap really
- Site Admin
Maybe when the locale is set to UK we don't get that option?Richard_R wrote: Mon Jan 31, 2022 9:38 pm On my XT there seems to be a global setting adjustment for either metric or imperial measurements.
Blame the Americans! they created it! Oh hang onStu wrote: Mon Jan 31, 2022 9:34 pm If that's true than it's lame. I'm in the US and can use C or F (and independently of mi/km setting). But the XT is depending on a locale?? In other words for Europe locations it'll say C and in the US - F? Hmm, Duno
[/quote]
Yeah, I know they still live in the past: yards, feet, temps, quarts, ounces, pounds, and don't let me start on fractions measurement
- Site Admin
I have just changed my locale to New Zeeland and when I changed between miles and kilometres the temp changed between the two
But put the locale back to UK and I only get Celsius
