Poor Bluetooth Quality
Has liked: 424 times
Been liked: 241 times
Re: Poor Bluetooth Quality
DiavelDes wrote: Tue Apr 05, 2022 9:31 am
jfheath wrote: Mon Apr 04, 2022 10:03 pm You have to use BT with the Zumo XT. I have found it to be very clear. - providing the BT devices are clear of the rear of the bike, where the ECU is located. It interferes with the reception very badly.
I get it crystal clear some times and crackly others, can be in the same day.
Thats the reason why I go through the phone rather than the zumo it is hit and miss :?
Has liked: 427 times
Been liked: 934 times
I haven't found it to be hit and miss - once I had realised that the ECU was causing problems.
I also used to have my phone plugged into the USB socket in my top box - but that would occasionally disconnect.
No such problems if it is further forward on the bike.
My BTM-03 Bluetooth transmitter / receiver is located under the dash near the headlights now.
jfheath wrote: Wed Apr 06, 2022 1:45 pm I haven't found it to be hit and miss - once I had realised that the ECU was casuing problems.
I have my phone mounted to my handle bars and the sat nav directly in front on me so not a lot between them
Although this was with the previous XT I haven't tried with the replacement one
I will also test away from the bike when I have chance so no interference at all
DiavelDes
Has liked: 4 times
Post by DiavelDes »
I've had the issue over 2 different bikes and 2 different Bluetooth headsets from different manufacturers Cardo and Sena.
DevonBiker
Post by DevonBiker »
DO NOT BUY! Very poor quality audio instructions via Bluetooth. I have a Sena which was made to factor fit my Shoei helmet. MP3 playback is hit and miss. Audio quality is “ok” but as soon as Garmin interrupts your music with instructions it’s absolutely diabolical. I have to turn off the navigation volume because it’s that bad. If I were to get the KTM MyRide to navigate me the quality to my headset is on par with Google or Waze but Garmin are miles behind the quality their sat navs need to be. Both my phone and Sat nav are mounted opposite ends of my handlebars. I won’t buy again from Garmin until they sort this out.
