CN EU 2023.10 NTU
Re: CN EU 2023.10 NTU
If you have older versions of the maps on a laptop or PC then Basecamp can install maps from this dataset. You just select the map version and the tiles to upload. Hold the mouse button down and drag the cursor to select multiple tiles. Right click to unselect a tile. It takes ages but I have UK, France & Spain back on my device from the 2022.22 maps. I had over half of the internal memory available, so sufficient. If you lack space then I assume you can use an SD card.
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
Scarecrow
- Has liked: 3 times
- Been liked: 28 times
Sorry Sussambsussamb wrote: Sun May 22, 2022 12:29 pm @Scarecrow
Have you tried deleting the downloaded map data already on your PC? Think you'll need to do that first, at least I did and it then worked.
I'm not That computer literate
but HOW do I delete the downloaded map data
It will show as an installed programme in Windows settings. Go to "Add/Remove" programme in settings. Simply type "add/remove" in the search box at the bottom left of your screen and follow the instructionsScarecrow wrote: Sun May 22, 2022 3:27 pmSorry Sussambsussamb wrote: Sun May 22, 2022 12:29 pm @Scarecrow
