Late to the party but let me add a few things.
temp.gpx, indeed any .gpx files you place in the GPX folder on your device, is merged with current.gpx when your device reboots and a new current.gpx written into the GPX folder.
current.gpx is simply a one way copy of what is in inaccessible to the user internal memory. Once the new current.gpx is written temp.gpx can be deleted
The TripPlanner app can handle up to 200 routes.
Imports failed. Does that mean internal memory is full?
Re: Imports failed. Does that mean internal memory is full?
I am very worried. I'm going on a road trip next week. I have created 9 routes with many WPs. I hope everything work well. How many WPs can I import?
Another question; I created the routes with the 2022.1 maps with Basecamp. Last week I installed the new 2023.1 update. With Basecamp I recalculated everything. All right?
Thank
Thank
There's a limit of, i think, 25 real(!) Waypoints per Route - including Start- and End-Point. If you use more, than the route will be splitted while importing it!
No need to use many 'real' Waypoints - they must be(!) arrived and you'll get troubles, if you put one or more mistakenly not exact on the road! You're only be able to skip a real waypoint with the 'Skip Waypoint' feature, driving by such a misplaced waypoint will force you to get back to it!
If the alarm isn't necessary, use the 'normal' shaping points, which Basecamp creates - some of them also could be with alarm, so check them before you transfer the route (double click the route and see in the list, if one or more of them isn't grey! The shaping points are commented with 'no Alarm'.
I only use waypoints with alarm, to remind me of filling up gas or so...
The used maps should always be the same on Basecamp and on the Zumo XT. Recalculating the created routes with 2023.10 before putting them on the Zumo XT is necessary, if the Zumo XT also has 2023.10 on it! Beware, that no one(!) of the options in Basecamp under 'Options/Unit Transfer' should be activated, when transferring the routes to the Zumo XT
Bye, Robert
- Has liked: 140 times
- Been liked: 437 times
It important to get them all imported immediately rather than having them sit in temp.gpx where they could potentially be deleted should the need arise to modify one in BC and resend it. The XT allows "Select all" in the import function so should be capable of processing "all". It appears to process them one at a time.rbentnail wrote: ↑Wed Jun 15, 2022 4:36 am"Having them all imported" and importing them all at the same time are not the same thing.Peobody wrote: ↑Wed Jun 15, 2022 2:07 am My upcoming 14 day trip is planned in 14 routes. I'm just trying to make my life a little easy by having them all imported so I can just select the appropriate one each morning and hit Start. On my last long trip I loaded the routes on the SD card and imported each one as needed. That worked fine but the list order of the route available for import didn't make any sense so having them all imported before I depart seems like it should be easier.
Raf, I think you will be OK. The important thing of making sure routing WPs are positioned exactly on a road has been mentioned.
I apologize if I created unnecessary concern. When I see things occur that I don't understand I push for understanding. This doesn't mean there is a problem. This discussion is a good example of that. My XT didn't import some routes that way I thought it should have and I started asking questions and digging for an explanation. I eventually attempted an import a second time and that worked. I could have just done that and not said a word.
I figured out what caused the import process to fail to import some routes. When the XT goes to sleep, processing is stopped. I have tried to match the XT profile to that of Basecamp but every route is going through a "Calculating" process during import. This is a timely process. Screen touches were required to keep it awake. Another oversite by Garmin developers; logical for a low battery condition but that wasn't the case for me.
Now I just wish I could figure out why every import goes through this calculation process. My next step is to load track and compare them to the routes.
- Has liked: 418 times
- Been liked: 908 times
A Waypoint is a point that has been created (perhaps by using the Basecamp Flag tool) and saved, prior to creating a route. Any waypoint can be added to a route and used as a shaping point or as a via point. A waypoint is simply a location that has been saved ready to be used in a route.Rofor wrote: ↑Wed Jun 15, 2022 11:16 am There's a limit of, i think, 25 real(!) Waypoints per Route - including Start- and End-Point. If you use more, than the route will be splitted while importing it!
I think that you are maybe confusing Waypoints with Via Points. I cant work out what you mean by 'real waypoint'.
There is no limit on waypoints that I am aware of. You can make all of your route points as waypoints (created with the Basecamp Flag Tool). They will all end up in Favourites / Saved. You can then set them all to be not alerting - so they are shaping points as well as being waypoints.
The limit is on the number of Via Points in a trip excluding start and end. That limit is 29. Create a route with 30 + start and finish, and it will split it into a route of 29 + start and false finish and a route of 1 + false finish as a start and real finish.
This is not correct behaviour. If you have problems due to the XT timing out, plug the USB cable into a power source so that it remains powered. Watch the screen - it will tell you that in 20 seconds it will enter file transfer mode. Cancel that and it will just keep the XT powered up.Peobody wrote: ↑Wed Jun 15, 2022 2:52 pm I figured out what caused the import process to fail to import some routes. When the XT goes to sleep, processing is stopped. I have tried to match the XT profile to that of Basecamp but every route is going through a "Calculating" process during import. This is a timely process. Screen touches were required to keep it awake. Another oversite by Garmin developers; logical for a low battery condition but that wasn't the case for me.
But your routes should not be recalculating.
These have come from Basecamp (yes) ?
In BAsecamp, click Edit / Options / Device Transfer.
Tell me which boxes you have ticked in that window.
(You should have none ticked, and then select Apply to all devices).
Let me know
IMHO, the XT should not timeout when it is busy calculating unless it encounters a low battery condition.jfheath wrote: ↑Wed Jun 15, 2022 4:57 pm This is not correct behaviour. If you have problems due to the XT timing out, plug the USB cable into a power source so that it remains powered. Watch the screen - it will tell you that in 20 seconds it will enter file transfer mode. Cancel that and it will just keep the XT powered up.
Yes, the routes are from Basecamp.jfheath wrote: ↑Wed Jun 15, 2022 4:57 pm But your routes should not be recalculating.
Let me know
None of the device transfer options are ticked.
