Windows 10 query
None Zumo related? then feel free to chat about it here anything goes.
kernowing
Has liked: 135 times
Been liked: 61 times
Re: Windows 10 query
Post by kernowing »
I've found Windows Media Player here:- Windows8_OS (C:) Program Files (x86)
I do get the option to delete it but would that be a sensible option?
I'm not too good with this stuff :?
2007 GL1800 Goldwing
Zumo 660LM
Been liked: 266 times
No don't delete it from there!
if it is installed that will not uninstall it and will mess things up further!
are you using a windows 8 pc updated to windows 10 by any chance?
kernowing
Post by kernowing »
Yes, I bought it with Win 8 installed and "upgraded" to Win 10 but that was soon after I bought the PC, more than 2 years ago.
Media player has always worked fine until a couple of days ago.
Zumo 660LM
I'm wondering if you have had some sort of update thats caused it to play up!
you could search cortana for windows media player and see if it finds it! might save a lot of looking
kernowing
Post by kernowing »
Cortana found it, I clicked on it and -----nothing?? I think there was an update some time last week. I'll maybe try and find that.
Thanks for your help Stu.
Zumo 660LM
I would look at downloading and re install it
it should give you the option to repair the current installation
kernowing
Post by kernowing »
Stu wrote: Sun Aug 26, 2018 8:50 pm I would look at downloading and re install it
Thanks Stu, think I'll get someone to have a look at my laptop who's a bit more clued up than me. I'll use "Power DVD for Lenovo" for now to play my Gopro stuff.
It don't take a lot to confuse me :?
Thanks again, Pete.
Zumo 660LM
kernowing
Post by kernowing »
Well, aint it odd how inanimate objects can make a plonker of you!! After my last post the laptop did an update, shut itself down, restarted and now Media Player is working again. It must have been the last update that caused the problem??
Zumo 660LM
issue solved :lol:
advnzer
Been liked: 8 times
New Zealand
Post by advnzer »
if something seems odd a restart often resets things back to normal
