Zumo 595 doesn't see route on SD memory card
LQQK_OUT
Has liked: 18 times
Re: Zumo 595 doesn't see route on SD memory card
Post by LQQK_OUT »
jfheath wrote: Thu Jan 19, 2023 10:28 am Just for amusement....
Creat a simple route in Trip planner and save it.
Then try to import the route again
If that doesn't work then-
Tap the map to get a flag.
Save the point.
Then try to import the route again.
I created a simple route using the "Trip Planner" and saved it. In the "Trip Planner", when you create a route, it is saved under the heading "Saved Trips". If you import a route, it is saved under the heading "Imported Trips".
Creating a route via the "Trip Planner" did not solve the problem.
I also tried your suggestion of tapping the route to get a flag and saved that point. Which placed a new entry in my Saved --> All Saved Places
That also did not fix the issue.
Zumo XT2, Zumo 595LM
2011 Harley-Davidson FLHTCU
1993 Harley-Davidson FLSTF
Has liked: 372 times
Been liked: 795 times
Ok sorry. I had the problem once, and I tried that trick which works with Waypoints saved to SD card. The same trick worked for me with routes only on the SD card.
Or so I assumed. I'll have to go back and try that again.
