595 Travel Edition Maps on the computer
Sleuth
Has liked: 14 times
Been liked: 16 times
Belgium
Re: 595 Travel Edition Maps on the computer
Post by Sleuth »
sussamb wrote: Wed Oct 17, 2018 8:20 am You can use TE versions with BaseCamp, but only with the device plugged in. The other alternative is to copy the maps to a SD card or memory stick and use that instead. Map files need to be placed in a folder named Garmin on the card/stick.
Perhaps a stupid question from someone who has had a number of years experience with Garmin.
But how do you actually copy the map-set (and make it work) to a USB drive?
Edit: I would like to plan for a trip to the States, as well as having a similar Europe map available.
Thanks
Sleuth
Maps: Europe NTU 2024.10
Has liked: 381 times
Been liked: 384 times
No such thing as a stupid question ;)
Copy the map file, will end in .img, to a folder named Garmin either on a card or stick.
Sleuth
Has liked: 14 times
Belgium
Post by Sleuth »
sussamb wrote: Sat Oct 20, 2018 5:16 pm No such thing as a stupid question ;)
Hi Sussamb
Thanks very much for the info. I hoped it might be that easy, but usually things are not as easy as it appears! :D
Best regards
Sleuth
Treve
Been liked: 3 times
Sweden
Post by Treve »
Halo.
I have a TE and try to copy the map so I can worke in BC without having my Z595 on. But I can´t find the map file. I have put my 595 into MSS mode and there are no file .img. I have the box "hiden objekts" checkt. I have tryed every singel map and can´t find the map file. I hate this TE. I did not knew there were that kind of edition when I bougt it.
Hope for help
Treve
Been liked: 3 times
Sweden
Post by Treve »
The total folder (F) Garmin zumo sise are 5,04 GB out of 9,24. The sise of the "Map-folder are just 15,3 kB!!!! The unit must hide the .img-fil somwere.
They are in the hidden .system folder. You'll only see it if you set Windows to show system AND hidden files/folders
Treve
Been liked: 3 times
Sweden
Post by Treve »
Halo sussamb
Many thanks for your quick respons. I have found the .System. My goal is to copy the maps to a stick in order to use it when I "works" i BC. Do you knew if it´s just the "gmapprom.img" I copy to a "Garmin-folder" on the stick?
The latest Europe-map is now so big that they have divide it in to four or five regions. Is it possible to have two or tree "gmapprom.img in the same Garmin-folder. If "yes" - maybe I should give them different names - eg "gmapprom1.img"?
Is it even possible to have more than one "gmapprom.img" in the .system-folder in my ZumoTE?
Relay appreciate your help.
Treve
Not sure how it works on your device but other maps are normally in a Folder named Map. I'm not sure either how the Travel Edition handles additional maps but if you search your device for .img files it should be obvious which are the map files
