max speed on power up
twowheelstom
Has liked: 100 times
Been liked: 40 times
Re: max speed on power up
Post by twowheelstom »
FrankB wrote: Tue Feb 06, 2024 6:28 pm I took the XT for a walk and managed to get the max speed to 15 kmh, not bad for 60+ years.
you're +60 and can walk 15 kmh? I'd say you're in tip-top shape. well done
Has liked: 120 times
Been liked: 168 times
twowheelstom wrote: Wed Feb 07, 2024 12:37 pm you're +60 and can walk 15 kmh? I'd say you're in tip-top shape. well done
Actually I cant believe it myself. The remark was to show that the Max Speed the XT displays should not be taken to seriously.
If you search this forum you can find some posts, that question the data. Probably caused by how the GPS works, combined with the calculation method.
How I understand it: Suppose you move from Point A, to B to C. And for the sake of simplicity suppose that point A and C had correct coordinates recorded, But point B is recorded more to A than C in reality. The average speed from A to B would be to low, and from B to C to high. Although the average from A to C would be correct. If the unit takes the max speed from B to C obviousluy it's not correct.
But at the moment I'm not feeling to bad. Thanks!
