Page 2 of 4
Re: CN EU 2025.10 NTU
Posted: Mon Mar 04, 2024 7:24 pm
by khunpaul
sussamb wrote: Mon Mar 04, 2024 6:31 pm If you're sure it's the old map you can just delete the file. However it shouldn't cause confusion unless you have both old and new map selected.
Screenshot 2024-03-04 192221.jpg (17.47 KiB) Viewed 6632 times
I think it must be the old map as seen on screenshot from basecamp.
Posted: Mon Mar 04, 2024 9:34 pm
by sussamb
You can confirm by comparing file dates ... or you can just leave it there, just ensure only one map is selected on your device.
Posted: Tue Mar 05, 2024 8:38 am
by paynes1
Just tried to update my PC and laptop. to 2025.1.
When updating PC I had error messages in GE several times at end of process, but kept trying and finally had success. Could not update laptop without getting the error message continuously. Tried all kinds of things suggested by Garmin support a couple of years ago when I had similar problems, although this is a new laptop that already had 2024.2 loaded without issue. Finally resorted to deleting latest version of GE (7.20?) and found a previous version of 7.18.40 and loaded that. Maps updated first time!!
I shall probably leave this version of GE until next update.
Steve P
Posted: Tue Mar 05, 2024 10:14 am
by colirv
raza wrote: Fri Mar 01, 2024 5:30 pm With new GE you can ´t install maps on jour PC. Error download.
Which is odd, given that one of the improvements with 7.20 is claimed to be "Resolved an issue with map updates failing to install to the computer".
Posted: Tue Mar 05, 2024 10:50 am
by sussamb
Well it worked for me :D
Posted: Tue Mar 05, 2024 2:11 pm
by Peobody
There are numerous posts on the Garmin support forum by folks having problems with GE 7.20.0.0, both in syncing and with map updates to PC. Reverting to a previous version is the common solution.
Posted: Tue Mar 05, 2024 3:07 pm
by lkraus
I wouldn't have a problem deleting the file even if I was not sure. You can always reload the current map.
Posted: Wed Mar 06, 2024 4:09 pm
by paynes1
I have just heard from Garmin support that errors loading 2025.1 are known. A new version of GE 7.20.1 is available which should have solved the problems with MSI.
Steve P
Posted: Sun Mar 10, 2024 12:19 pm
by Scottnet
Scarecrow wrote: Fri Mar 01, 2024 5:48 pm
With old ver. install without problem.
I managed o with no problems
I have the same issue, in that I can't install this map to the PC. Any idea how I can downgrade GE ?
Posted: Sun Mar 10, 2024 1:57 pm
by Peobody
I have seen reports that Garmin Express 7.20.1.0 has solved the problem of map install to PC failures.
As to where to find older versions: https://garmin-express.en.uptodown.com/windows/versions
