Deleting old maps.
Re: Deleting old maps.
In Basecamp: Maps / Manage Map Products
This dialog box tells you exactly where each map is stored.
When the Zumo is connected, the library pane on the left shows which maps are installed on the Zumo. Click on any map, and the bottom pane will reveal the name of the img file for the selected map. These files may be in .system/Map.
Additional files that are associated with the .img file have the same name but different extensions.
eg D6159300A.img, D6159300A.gma, D6159300A.unl
wks
Has liked: 27 times
Post by wks »
Thanks John. On my Map Product Manager screen i have the latest NT map and the latest NTU map. I also have a NT map from 2008 which i either bought or it came with my 550. Is that one ok to delete ?
TIA
Yes, unless you wish to keep it
colirv
Has liked: 66 times
Been liked: 64 times
Post by colirv »
On my PC I remove old maps using the Windows Uninstall feature. Saves messing about with folders.
Colin
BMW R1250RS
https://www.namrider.com
wks
Has liked: 27 times
Post by wks »
Many thanks to everybody.
colirv wrote: Sat Dec 21, 2024 2:39 pm On my PC I remove old maps using the Windows Uninstall feature. Saves messing about with folders.
Unfortunately that doesn't delete the install files that Express leaves behind.
colirv
Has liked: 66 times
Post by colirv »
sussamb wrote: Sat Dec 21, 2024 7:56 pm
Ah! They're hidden away in the RMU folder. Thanks for that.
Colin
BMW R1250RS
