Didos wrote: ↑Sat Feb 01, 2025 2:32 pm
Some hicups..
.. When transfering the track to route.. After 94%, I had a message from XT of cannot make route
I uploaded same route, different way points, and it worked.
That can happen a lot. I often find that If I ask it again it gets a bit closer to completion. Then ask again etc. If they don't complete in the first attempt, they usually complete after three or 4 attempts. Not always though.
I don't use this method very often - only really to check out what it does.
As you said, I don't viated for petrol, I saw the magnet line, I went.. Continued for 10 min then XT lost direction on roundabouts.. Tried to rectify but no success.
All sorts of things could be going on here. I suspect that when you stopped for petrol, the XT was turned off, and it lost the route. In that case - or if things are not doing what you expect - stop the navigation (main screen - Stop), and then reload the Tip from the Tripplanner, select go, and then select Closest Entry point.
This is a good emergency standby. The closest point on the route from where you are now, may be not quite where you think. Eg if the route is generally heading north - it could mean having to head south - simply because you can join the route in 4 miles if you head south, but if you head north it is 5 miles before you join the route. So head north for a couple of miles and then try again !
There are also issues with circular routes - because the closest point might well be 2 miles away on the road that you will take to get home.
Personally I do not use trips that have been created from Tracks. But I know that a lot of people do.
One thing that I found that was surprisingly good (although I still don't use it) - is to load a track and select Go !. You get the purple line plotted from your track and if you stray away from it, it plots a dotted straight line in the direction of the point that it thinks is closest on the route, and tells you how far away that point is. The purple track stays fixed in place - so if you zoom out far enough you can always see it.
Its like having a paper map that automatically trune pages - with the route marked with a highlighter pen, and a back seat driver quietly saying 'You need to be be heading in that direction over there'. But it gives no instructiosn at all. When I first read about it, I though it would be a complete waste of time. But it turned out to be quite refreshing.
Images of this - See "Navigating with the aid of a Track" halfway down this page
app.php/ZXT-P48
