Page 2 of 2
Re: Update to Europe NTU 2026.1
Posted: Wed Mar 05, 2025 12:30 am
by lkraus
"Extra" City Navigator maps, whether purchased on SDcard or via download, do not update and cannot be downloaded to a computer. They can only be used with the XT connected. The EU map is in two parts because the FAT32 SDcard has file size limit of 4 GB. Do not delete either one as they cover different portions of the EU.
Posted: Wed Mar 05, 2025 3:52 am
by federico
Thank you very much. One piece of the puzzle fixed!! Safe rides. Ciao
Posted: Sat Mar 08, 2025 11:03 am
by MacrosTR
Hi Federico I am in the same situation as you are. I purchased zumo xt2 from USA and installed NTU Euro Map on July 2023, No updates since that date. Deleted maps, reset device, tried all but 2026.1 is not there. Removed North America Map but still same.
Posted: Sun Mar 09, 2025 6:52 am
by sussamb
As already posted, you cannot update purchased maps, just the one that came pre-installed on the device.
Posted: Sun Mar 09, 2025 12:37 pm
by lkraus
Roads do not change frequently. We made cross-country trips with a TomTom GPS with the original map from 2009 to 2022, no problems. Only stopped using it because Google Maps on the phone was more convenient.
If my City Navigator maps stop updating, or if I needed maps of a different country, I would use OSM maps from
OpenMapChest.org. They are very detailed, most POI are searchable, cost is zero if downloaded with a torrent client, and they are updated weekly. Compared to the Garmin map, the only missing feature that I have found is that my XT does not show the speed limit.
Posted: Sun Mar 09, 2025 7:38 pm
by Mzokk
lkraus wrote: Sun Mar 09, 2025 12:37 pm
Whether speed limits are displayed or not is the choice of the person garminising the OSM mapping. The look of the map can also be changed. I do my own now using MKmap and Splitter (which are command line utilities)
Here is a few screenshots of various maps on an old NAV IV (Garmin 660) in simulation mode.
Freizeitkarte
- 1730242310359.png (95.79 KiB) Viewed 4904 times
Alternativaslibres
- 1730242339193.png (77.42 KiB) Viewed 4904 times
My OSM Map
- 1730242403526.png (92.92 KiB) Viewed 4904 times
Garmin Map NT2025.1
- 1730242450069.png (65.99 KiB) Viewed 4904 times
When I make my own maps I tend to keep with the Garmin look and feel and don't include speed limit info (it tends not to be that accurate anyway even with Garmin's Here mapping). As you can see from the Freizeitkarte and Alternativaslibres maps if you create the maps yourself you can customise the look and feel. My own maps even work on my First GPS a Streetpilot 2610 which last had a garmin map update in 2008.
Posted: Sun Mar 09, 2025 7:59 pm
by federico
Thank you to those who took the time to comment my post. I am learning each time. Now
it is clear to me that the real trip is travelling the learning curve BaseCamp-Zumo..!
Posted: Mon Mar 17, 2025 12:01 pm
by MacrosTR
sussamb wrote: Sun Mar 09, 2025 6:52 am
Sorry, I don't see your post. Thanks for clearing things up.
Posted: Wed Apr 30, 2025 6:18 am
by Erik93
Greetings.
I need a lot of help from you. I have a Zumo 595 navigation system that I use on my motorcycle but I can't update the map. After Express downloads the map and starts copying it, it says: There was an error installing the update. What could be the problem?
When I try to download it to my computer, it doesn't work. I'm completely at a loss as to what could be the problem
Could it be some kind of authentication problem? All other minor updates that are available can be installed without any problems.
Thanks in advance.
Posted: Wed Apr 30, 2025 7:08 am
by sussamb
Please start a separate post rather than piggy backing on this one, as yours is a different issue. Thanks
