reverse polarity, in my testing I think i did that, I think I damaged the dc-dc converter box, disconnecting to 12v doesn't reset the converter, I may have ruined it,
new 396 power cable arrived
- twowheelstom
- Has liked: 114 times
- Been liked: 40 times
Re: new 396 power cable arrived
2005 Kawasaki 800B cruiser
- Has liked: 71 times
- Been liked: 191 times
Maybe. I've read of several cases where reversing polarity did not work, but did no damage. I do not remember if those were the new fuseless converters or the older fused ones.
- twowheelstom
RESOLVED MY PROBLEM
well, it was a reverse polarity, and I ditched using the battery clamps I was using, and connected zumo cradle power cable directly to the battery posts, and guess what, the 396 powered on, success, I believe the testing I had been doing with the battery clamps was the problem, connecting cradle wires directly to (+) and (-) battery post solved my problem, yahoo, now I realize that I was doing it wrong, no wonder the zumo had no power, my battery clamps are a reverse polarity, whereby the red clamp is the (-) and the black clamp is the (+) lol I am so dumb
- twowheelstom
You helped me a lot Ikraus, especially with your comment about reverse polarity, your comment sent me on a search to learn what it is and I checked my test clamps and bingo, problem solved, so thanks
