Page 2 of 2
Re: Garmin Express no Longer Allows Map Downloads To Computer
Posted: Sat Sep 11, 2021 8:02 am
by kristaps78@gmail.com
Same here. I have mac mid 2011 and zumo XT. Garmin Express will offer to download map on computer but when I do, nothing happens, bar with download speed, percentage, time is not moving. I restarted everything, it doesn’t work.
Posted: Sun Sep 12, 2021 2:39 pm
Welcome to the forums !
Glad you managed to find the maps. You need to make sure that your Zumo and Basecamp are both using the same version of the map. I notice that you still have two other versions on the computer - check that Basecamp is showing the correct map on the menu bar drop down selection box.
Also - if you load routes that have been created using the older maps, make sure to recalculates them for the newer map if you wish to transfer to the Zumo again.
Posted: Wed Oct 27, 2021 10:40 am
by Twin4Me
Just an update, I got so fed up with Basecamp that I've now converted to My Route App, what a revelation! So much easier to use and the option to overlay Michelin or Google maps is a joy.
