395LM Stuck in boot loop
Stotty
Re: 395LM Stuck in boot loop
Post by Stotty »
Hi Totti,
I have the Garmin cure file and the GCD (firmware) file for a 395LM.
Let me know your email and I'll send them over to you.
Colin.
Totti
Finland
Post by Totti »
Stotty wrote: Thu Jul 06, 2023 11:51 am Hi Totti,
Colin.
Just sent you PM.
Totti
Finland
Post by Totti »
Got mine working again!
I was able to download the firmware from Garmin website and the "Garmin Cure" from the gpspower-forum.
It was a bit of a pain to get the timing just right with the preboot-mode.
Unlike in "daniel87"'s case, I got an error when trying to launch the "updater.exe" from "Garmin Cure".
Noticed that it made a temp folder under the folder it was ran. Moved the "updater.exe" -file to this folder and ran it from there without any problems.
The "cure" option in "Garmin Cure" worked fine, but the "original" option did not work. It jammed the device.
Finally I ended up formatting the whole device using "RMPrepUSB" software and installed new firmware with the "Garmin Cure".
This trick worked and now the device is working properly!
I copied all the files from the Zumo before formatting. This was a good thing, because I was able to copy back the right language and keyboard files.
Did not install any Garmin-maps, because for some reason this take hours to finish.
Running the device with osm-maps and maps from the National Land Survey of Finland.
Stotty
Post by Stotty »
Good result.
I'm glad you got it sorted.
Colin.
Hansmuster
Switzerland
Post by Hansmuster »
Hi
My 395LM stuck in the boot loop after updating the maps.
I have read the discussion, what I can't find on the internet is the GCD (firmware) file for the 395LM. All links do not work.
Does anyone have the firmware for me?
Stotty
Post by Stotty »
Hi,
I have a copy of the firmware. If you pm me your email and I'll send it to you 👍
mlinke
Post by mlinke »
Hello
I just need the Garmin cure 3 program. I cant find it anywhere to download. Please someone put a link
Totti
Finland
Post by Totti »
Hansmuster wrote: Sun Jul 23, 2023 10:11 pm Hi
Did you get the firmware? I downloaded mine from this address :
Zumo firmware
Zumo firmware
The spelling and capital letters needs to be exactly the same.
Hope this helps!
Just click the link, save some typing:
https://download.garmin.com/software/Zumo3x5_460.gcd
