Re: Xt power draw
Posted: Sat Aug 26, 2023 3:50 pm
For the Anker stuff you might want to look at this page: https://www.howtogeek.com/769888/what-i ... ry-usb-pd/
It seems to be a little more complicated than just assuming a blue USB port will be sufficient.
Anker mentions "Power Delivery 3.1" which standard allows for the delivery of up to 240 Watts over some USB cables or ports. The max current over USB according to the 3.1 standard seems to be 5 amps. The power increase is obtained by increasing the voltage. The original spec for USB was 0.5 Amps. That limit appears to have been gradually increased to 1.5 amps (about 7.5 watts) without some voltage/amp controlling standard.
You might want to ask Anker for the max current output from their battery banks. It also would be nice to know the XT USB spec.
