both showed the issue in simulation mode & when actually riding the bike as mentioned in a previous post, but hey ho
Just to put it to rest, have done the test requested with a route created from Waypoints in Bascecamp & no surprises,
it does exactly the same thing as per my previous post, the issue is not MRA
It does smell similar to the RUT problem so I ran the same BaseCamp route generated from Waypoints (attached) through the web version of the trip repair tool https://www.javawa.nl/triprepair.htm
Issue still behaves exactly the same
I think we will find that somewhere in the XT route calculation algorithm some dumb softie has a counter which is either over or undercounting the number of route points & it is attempting to recalculate using the wrong earlier route point
To me it does mean that Closest Entry is pretty much borked unless used at the beginning, in the first segment of a route
