Page 3 of 3
Re: BT Headset for XT needed any ideas?
Posted: Sun Dec 24, 2023 9:17 pm
by rbentnail
twowheelstom wrote: ↑Sun Dec 24, 2023 8:51 pm
For your bluetooth adapter, do you also have an attached usb power bank to it to make the adapters battery last longer?
I got my receiver but wondering if the small battery in the adapter is enough to play music from the zumo on a long ride.
Nope, no power bank here. The adapter I got lasts at least 10 hrs playing music from the XT SD card and giving turn instructions. If I were you I'd try it out before worrying about it.
Posted: Mon Dec 25, 2023 11:26 am
by twowheelstom
I found online specs for my ugreen bluetooth receiver it's a 300mAh battery, and since I worry about having a dead battery on a ride with no audio, so I bought myself a Christmas gift on amazon the INIU Portable Charger, 𝟐𝟐.𝟓𝑾 USB C 10,000mAh Small Power Bank, 1 usb-c in/out and 2 usb-a out, little compact unit for my pocket to be connected to the receiver at all times, this was 1 of the things I was worrying about going from bike powered earbuds on the 550 to battery powered earbuds, ya I know I shouldn't worry about losing audio on a 396 but I do lol, Christmas morning, Merry Christmas
Posted: Fri Dec 29, 2023 7:30 pm
by PhillH
I have used a Samsung HS3000 for years with the Zumo 600 and now the XT. It cost £20 is very small and fits in the helmet behind one of the cheek pieces in my shoei. I stripped apart and mounted a cheap pair of earphones in to the helmet which plug into the unit. I also have an extension cable pluged in for charging which tucks out of the way when not in use. Works a treat but the HS3000 is discontinued so I will neeed to look for something similiar when it finally fails. You can find a similiar units available but they are all square whereas the HS3000 was finger shaped and thin. I get a full days riding with music playing.
Posted: Sat Dec 30, 2023 11:58 pm
by rbentnail
Making any progress? I might be! By Bluetooth pairing the adapter and the XT, I got turn instructions and the music played from the SD card. I also had my Android phone paired to the XT for Garmin Drive app weather, traffic, etc. messages. I've been doing these for a while.
Today I figured out how to play music from the phone, through the XT and to my adapter where my earbuds allow me to hear. Wow! I'm not techno-geeky in the least so this is a great victory for me! Next test is to have an active route running to see if I get what I want- music from phone, music stops, get turn instruction, music restarts. This is gonna be so great!
Posted: Sun Dec 31, 2023 12:57 am
by twowheelstom
rbentnail wrote: ↑Sat Dec 30, 2023 11:58 pm
you're helping me learn stuff for my new 396 coming Tuesday, keep doing good work cause it's helping me, you inspired me to get my bluetooth receiver, when the 396 comes I want to pair the receiver to the 396 for starters, to get navigation audio and music like you have, you're doing a good job.
Posted: Sun Dec 31, 2023 7:04 pm
by rbentnail
All stop! What worked yesterday didn't work today. This is what I had:
XT BT paired with phone. XT BT paired with BT receiver. Wired earbuds plugged into receiver, one inserted in ear. Started route, initial instructions came through earbud. I could play music from the XT SD card through my earbud. Stopped route and while the music was still playing from the SD card, I restarted the route. Music stopped, audio instructions came through the earbud, then the music started playing from the SD card again. Perfect! I had all this before so nothing's changed.
Then things went south really fast. On the XT, I stopped the music from the SD card and then changed the source by selecting my Android phone. I checked the menus in both my phone and the XT and both said each was paired with the other. I opened a music app and pressed play. The music plays, but it comes out of the phone speaker. Crap! I spent 25 minutes trying all the things I've read about- unpairing, repairing, rebooting, removing devices from the area, etc. What a frikken cluster-F!! I finally got the phone music to play through the earbud but I have no idea what I did to make it work. Double crap! So I took a little ride on my route and everything worked- music from phone, stops, turn instruction, music restarts. All through the earbuds. I get back home and stop the route on the XT. I exit from the app on the phone. Here's where things go farther south b/c simple, stoopit me thinks, "if it worked once, it'll work again." Nope, music plays from phone speaker.
