Re: Start point, how far to avoid RUT?
Posted: Tue Jun 18, 2024 10:48 am
Dedicated forums for Garmin Zumo motorcycle satellite navigation. All questions answered from problems, route planning, touring to tips and tricks
https://mail.zumouserforums.co.uk/
The 590, 595, XT and XT2 will navigate you from where you are to the selected point (Start/ Selected Via/Closest Entry), and will then continue navigating the plotted route from there. Navigation is therefore seamless - it treats the selected point (eg start) just like a mid route Via point. If you look at the preview map, it even shows your current position as a green flag and the selected start as an orange flag.Rofor wrote: ↑Tue Jun 18, 2024 10:28 amHopefully i didn't misunderstand your concerns...OldRS wrote: ↑Mon Jun 17, 2024 4:09 pm I do not know what "RUT" stands for but, as afar as I am concerned, the most significant failing in all of Garmin's products after the 550 was the removal of the the option to be guided to the start of a route or for the device to monitor ones progress and start guidance when the route was crossed.
You'll be automatically guided to the starting point of your route when you are not near it, at least with Zumo XT - also when you are leaving the active route and you re-join it, the navigation will be continued automatically!
My experience with the 595 is that it doesn't offer closest entry. Is that a new feature?jfheath wrote: ↑Tue Jun 18, 2024 4:10 pmThe 590, 595, XT and XT2 will navigate you from where you are to the selected point (Start/ Selected Via/Closest Entry), and will then continue navigating the plotted route from there. Navigation is therefore seamless - it treats the selected point (eg start) just like a mid route Via point. If you look at the preview map, it even shows your current position as a green flag and the selected start as an orange flag.Rofor wrote: ↑Tue Jun 18, 2024 10:28 amHopefully i didn't misunderstand your concerns...OldRS wrote: ↑Mon Jun 17, 2024 4:09 pm I do not know what "RUT" stands for but, as afar as I am concerned, the most significant failing in all of Garmin's products after the 550 was the removal of the the option to be guided to the start of a route or for the device to monitor ones progress and start guidance when the route was crossed.
The 660 - if I remember correctly (which these days is much less of a certainty) - The 660 would ask if you wanted it to navigate to the start. If you said yes, it would navigate you to the start and then stop. You had to reload the original route. I used to have the route loaded and ready to press Go! and wait until After I had passed the start point. Unlike the later Zumos, you could join the route anywhere and it would navigate you from that point forward. (Happy to be corrected on that - I cannot remember what the 550 did, so I may be confused)
Which is why if you put your home as a destination and started the route it would tell you that you had arrived and stop navigation.
That saves a a whole load of petrol. And time.![]()
Pics of the approach offered by the 550 attached. The Hawes-Whitby route has only a start and finish and no waypoints. If I choose not to navigate to the start point the 550 will begin providing instructions if I cross the route. 559 will not do that unless, as you say, you add a waypoint etcjfheath wrote: ↑Tue Jun 18, 2024 7:39 pm @OldRS Yes. Closest Entry point was introduced with the XT. It works well some of the time, depending on circumstances. You just have to look at the preview map - make sure it is taking you where you expected.
If you have a few Via Points in your route, then on the 590/595 they can be used (sort of) to start a route part way through - as they appear in the list of 'Destinations' from which the Zumo will begin navigating the planned route when you press Go!
On those devices you could select the last Via point that you had already passed through as the next destination and then skip the shaping points until it starts navigating ahead.
That method is not advisable for the XT.
If you encounter the route between the start and finish points, routing instruction to the finish point commences without any futher questions. Such a useful and, to my mind, obvious feature. I did discuss its loss with Garmin as did members of the original Zumo forum. Garmin was never able to provide a convincing explanation and I think that the furore caused by the, frankly not fit for purpose, display on the 590 allowed it to be forgotten.
Back home now - The XT2 comes with 6 Europe maps. Listed on my XT screen they are :
Thank youjfheath wrote: ↑Thu Jun 20, 2024 4:41 pmBack home now - The XT2 comes with 6 Europe maps. Listed on my XT screen they are :
EU adventure Roads & Trails
Europe DEM (thats the digital elevation map)
CN Europe NTU - All North
CN Europe NTU - All South
CN Europe NTU - POIs
TopoActive PS Lite, Europe.
(The XT came with 3 areas for Topocative PS - Europe Central, Europe West, Europe East - so the XT2 version appears to be much slimmer.
The america maps I have loaded (8 of them)
CN North America NT - ALL US
CN North America NT - All Canada & Mexico
TopoActive PS Lite, North America
NA Adventure Roads & Trails
North America DEM
CN North America NT - POIs
NA Adventure Roads & Trails : Offroad Areas
National Parks v2.
