Page 3 of 3
Re: Base Camp and Google Earth - again
Posted: Sun Nov 15, 2020 5:10 pm
by paynes1
As I understand it, you need GE version 7.3 + to get street view to work but that does not work with Base Camp 4.6.2.....
Posted: Sun Nov 15, 2020 5:38 pm
by sussamb
I'm using 7.1.8.3036 (32-bit) which is GE pro, but just checked and no longer street view :twisted:
Will have to do some experimentation.
Posted: Sun Nov 15, 2020 5:58 pm
by sussamb
OK, can't at the moment find any earlier version of GE that has street view and works with BaseCamp. Work around is to export BaseCamp data as a kml file and then import it into GE. Bit of a pain but it works.
Posted: Sun Nov 15, 2020 7:08 pm
by paynes1
Hi sussamb
Still using BaseCamp 4.6.2 as you suggested before and it still does the job linking with GE 7.1.8.3036 . Like you I use this to look at detailed locations on my route, but at the moment can only zoom in so far then no further.
To get detailed view of a point I select point in BaseCamp then select view/Google Earth/selected items. When GE opens I select File/view in Google Maps. When this opens in my browser I drag the man to the point and get street view. Long winded but at least a means of getting a detailed view.
I wasn't able to find an early version of GE that works with BaseCamp other than the one we use either.
Steve P
