haug37 wrote: ↑Fri Apr 25, 2025 7:10 am
And it will not be better, not to use Garmin Basecamp for tour making?
In spite of what Garmin says, Basecamp is still the best tool for the job (in my opinion). Garmin have stopped allowing their maps to be installed on the computer if you are using an XT2 - but I have older Zumos and can install it on the computer using those.
I'm not interested in the Michelin roads or different routing options for each segement. I want my satnav to take me on the roads that I have spent time planning to ride.
So I plan using BAsecamp.
I create a gpx file
I send it to the Zumo using TripManager
I do not allow the Zumo to synch to the Explore database either in Drive (for the XT1) or Tread (for the XT2).
And my routes behave perfectly. They take me exactly where I want to go.
I just have to get myself used to the fact that if the Zumo recalculates (XT1 or XT2) it is going to want to use main roads. Intelligent use of a few shapingpoints deals with that.
TripManager keeps the names that you have given to your route points.
It prevents the 'RUT issue' and the 'disappearing route point issue' from happening
The route or route points are never moved
It will create a track from your original route (from Basceamp routes) MRA1.1 doesn't create an original route, but it does export a track.
