Page 4 of 40
Posted: Wed Feb 28, 2024 1:08 pm
by man_mark_7
Same here, odd the Android app version of Tread only went from 2.08.28 to 2.08.29.
I did notice that if I change a track color on the Tread app, it syncs to the XT2, but the track always opens showing track color as "acceleration" instead of "none". Also on some tracks if I flip to "none" it still shows the same multicolor view I see in all the other "speed", "acceleration", "sharp turns". views and they all look identical.
2 steps forward, 1 back.
Posted: Tue Apr 30, 2024 5:47 pm
by turbo19
New Software versión for the XT2 4.70
- 1714499009686.jpg (295.7 KiB) Viewed 7181 times
has anyone tried it? Thanks,
Posted: Thu May 16, 2024 5:32 pm
by turbo19
New Tread version for Android 2.08.30 (2024-05-06).
- Tread.jpg (149.55 KiB) Viewed 6982 times
Posted: Fri May 17, 2024 5:16 pm
by turbo19
I´ve done some tests of the new version 2.08.30:
- I cannot design routes with off-road tracks with the Tread App, in any of the modes (Adventure, shortest route, etc.). In all of them, recalculate a straight line and not draw the route on offroad tracks.
- When I design the same offroad routes on the XT2 device, then it does draw the routes in the route planner, and I get it to draw the offroad tracks.
- I have been checking all the route settings and there are no prohibitions in either of the 2 planners. Previously, the Tread app allowed offroad routes to be drawn perfectly when a WP was placed in the middle of an offroad track.
- It seems that if I check the "avoid unpaved trails" option the Tread App route planner works better
do you have this same problem? Thanks
Posted: Fri Jul 12, 2024 9:51 am
by turbo19
New Tread version for Android 2.08.35 (2024-07-08)
from Garmin website:
https://support.garmin.com/en-CA/?partN ... b=software
Version: 2.08.35
Release Date: 7/08/2024
Fixed various issues
Posted: Fri Aug 02, 2024 10:55 am
by turbo19
New Tread version for Android 2.08.36 (2024-07-24)
- Tread app updates.jpg (132.38 KiB) Viewed 5528 times
Posted: Sun Aug 04, 2024 6:30 am
by Sean OZ
Garmin made out that the new Tread APP was going to be the "Bees Knees" for the new Zumo XT2. Seems that so far, it's as about as useful as a dead Blow Flie floating in a dunny bowl!
15 Aug 2024 Garmin Tread App update
Posted: Thu Aug 15, 2024 9:45 am
Update available for both android and ipad in last 7 days.
- Screenshot 2024-08-15 at 10.48.53.jpeg.png (434.59 KiB) Viewed 5363 times
Re: 15 Aug 2024 Garmin Tread App update
Posted: Thu Aug 15, 2024 2:42 pm
by lkraus
I love it when companies provide detailed release notes so I know what bugs have been fixed and I can fully appreciate all the new "functionality".
Posted: Thu Aug 15, 2024 3:02 pm
by turbo19
Thanks
@jfheath . Please use the "Latest XT2/Tread" post for this, that way we can have all the posts together. Thanks for the info.
Ok thanks for spotting this. I Missed this thread - now moved to here. jfheath (moderator)
