Hello Harry,
HarryMJ wrote: Sat Feb 08, 2025 10:26 am
Seems like only GPX files exported from BC will work correctly, is that a correct assumption?
No, GPX files from other planners should work. Provided they meet some basic standards. The truth is that I have only tested BC and MRA V1.1
I have attached a file exported from TourStart that have this issue, exported as route.
I had a look at the GPX (Thanks for that) and I can see what's bothering TripManager. The Name of the trip is in the
!CDATA format. When I change that to 'normal characters' it loads just fine.
This is what I changed:
I will see if I can change the program to accept also that format. Maybe you can check if there is a setting in TourStart to get only 'normal characters''?
(maybe it's enough to replace the last character. The
a with a little circle on top)
- compare.jpg (157.82 KiB) Viewed 6065 times
How it looks on my XT after importing.
- 8681.png (503.4 KiB) Viewed 6065 times
- 7512.png (115.77 KiB) Viewed 6065 times
- 6943.png (119.04 KiB) Viewed 6065 times
Frank
