Locking device for the XT
fortizgarcia
Been liked: 6 times
Re: Locking device for the XT
Post by fortizgarcia »
Finally I received it last Saturday, I enclose a few pictures for those that are interested in get it. ImageImageImageImageImage
Enviado desde mi SM-G973F mediante Tapatalk
akhaines525
Post by akhaines525 »
Has anyone used the Zumo Lock XT with the Evotech mount for the Zumo xt? Any issues or problems?
woodyflyer
Been liked: 5 times
Post by woodyflyer »
No happy about my XT not being very safe and secure while on the bike ,ie at petrol station /paying for the fuel, all it needs is a quick press of the mount clip and it's off and away by some vilian ☹️
To act as a deterrent and make it harder to be stolen, I decided to make a simple and cheap solution.
The idea is that the clip can't be pushed down to release the XT from the mount, plus I added a tether for extra security.
Took about a hour to make , a bit crude but effective , if anyone interested in how it's made let me know.
Woody
xedysx1986
Poland
Post by xedysx1986 »
I canceled the order for zumo lock, very good solution and cheap, where did I get the right parts? I understand that I can also use suitable Hinges.
Been liked: 265 times
woodyflyer wrote: Mon Oct 05, 2020 10:30 pm No happy about my XT not being very safe and secure while on the bike ,ie at petrol station /paying for the fuel, all it needs is a quick press of the mount clip and it's off and away by some vilian ☹️
Woody
Just make sure you don't leave the key on the lock :lol:
I think you should do a separate post with how you made it :D
woodyflyer
Been liked: 5 times
Re my DIY lock for the XT
Thanks for the comments.
I'm away up to Scotland till next week , so on my return the lock would have been put to the test .
On my return I'll post how I made the lock to help others who are interested in making one
Woody
Exurban
Has liked: 5 times
Been liked: 8 times
Post by Exurban »
woodyflyer wrote: Mon Oct 05, 2020 10:30 pm... all it needs is a quick press of the mount clip and it's off and away...
Yes, it’s that easy. In my pocket it goes when I’m out of sight of my bike so, no need to worry about villains.
REHTony
Sweden
Post by REHTony »
Not a locking device but an easy and cheap way to have Zumo XT securely attached to the mount: I just bought RAM rubber strap (RAM-HOL-UN10TU), se attached photos. Works great :-)
Garmin Zumo XT
Royal Enfield Himalayan
Sweden
Exurban
Has liked: 5 times
Been liked: 8 times
Post by Exurban »
I think that looks like a great solution for those who feel they need a tether. I was concerned the rubber straps would cover the corners of the screen but, it looks fine. And unlike a tether you don’t have to glue anything to the back of the XT.
yamaha07
Sweden
Post by yamaha07 »
Today I make a "locking device" Thanks "woodyflyer for the idea
Locking device.jpg (190.79 KiB) Viewed 6371 times
