Page 5 of 5
Re: map too big for Zumo? how to install on SD card
Posted: Tue Aug 17, 2021 7:27 pm
by hammer
As already posted, the "solution" doesn't work for me. When trying to use mapinstall (which is also how basecamp installs maps) I get maps locked notice eventhough maps are unlocked in basecamp.
Posted: Wed Sep 01, 2021 10:45 pm
by 93aspy
carolinarider09 wrote: ↑Wed Jun 16, 2021 1:11 pm
I am not at a place where I can look up what I use to do to make this work on my 665. But I did send my 665 off to the Palm DR and got a 16GB chip installed and the issue no longer exists. Well worth the money and removes the issue of map file size.
Again, not an immediate help for you but just one more option.
I second that. Send your unit to Chris Short at Shorttronics AKA Palm Doctor. There are 2 options available. An 8 gig or 16 gig memory upgrade. I did the 16 gig and the entire north American mapset is installed on my 665. I have used Chris for a few repairs now. He is fast, courteous, and knowledgeable. You can't go wrong sending your unit to him...
https://www.palmdr.com
Les.
Posted: Mon Sep 16, 2024 1:12 pm
by NeilP
Zumo 660.Latest and last NT Europe 2025.10
This thread did give me the solution.
Still cant get the entire region, since the 2025.10 map is 6Gb and limit seems to be 4 Gb due I guess FAT32
I was insitially confused aboutthe instructions to use BaseCamp to sned the map as it does not give that optoion directly
Seem you need to chose at least one waipoint to brign up the Send to Device Window, and then use the "Send Maps" option that then launches Map Instal AND IT IS MAP INSTALL that offers to send the map to SD card.
That has taken over a year to work this out...
or actually remember it as I had done it in the past
So for myself or other in future.this is reminder pn how to do it
Open BaseCamp
Send a Waypoint
Choose to Send maps to device
then select the SD card and Options and select the areas you need.
Posted: Mon Sep 16, 2024 1:31 pm
by sussamb
I've never needed to send a waypoint prior to sending a map. If it works for you though ...
Posted: Mon Sep 16, 2024 2:46 pm
by NeilP
Maybe if I go in just with map Install and not via baseCamp it may work with not waypoint
