Page 5 of 5
Re: Routes Prepared in MyRouteApp - Used with XT
Posted: Wed Oct 05, 2022 10:50 pm
Yes- thanks @mad-dawg - I sent an email reply on Sunday.
Thanks for the additional information. I have a case lodged with Garmin about the broken track log and the U turn issue. They repsonded yesterday - and are suggesting (again) that it is satellite reception causing the issue, in spite of the fact I have the active track log being broken, but the manually recorded track log on the same device at the same time not broken.
My track log also has a number of spikes - which is odd - but common - although I went back to logs from years back, and these do not have them - but that seems to be a different issue. I need to go back to your track logs and see if yours spikes as well.
I'm interested that you have also noted that sometimes the U-turn issue doesn't present itself. (And Garmin say they have been unable to reproduce 'it'- but I am not sure whether they are referring to the broken track or to the repeated U turns messages which is when the broken track is created. They want pictures of how my satnav is mounted - see if they can pin the blame on a broken signal.
I've spent a bit of time checking out my electrical supplies to eliminate the possibility of a faulty connector, but still have work to do on that.
I'll keep you (and this thread) updated.
Posted: Thu Oct 06, 2022 1:27 pm
by mad-dawg
Good man!
The satellite reception thing has to be a load of tosh! On the way back I went through westerscheldetunnel in Netherlands, its 6.6km long and the track log shows me entering, travelling through it and leaving. The XT may assume that as I entered the tunnel I have to come out the other end, which I did and it would then pick up reception again and continue the track log. The screen shot below shows the track log, no gaps, and I know it wasn't shouting at me to do a U turn.
In Monaco when I was doing the Meerkat thing, the XT was steadfastly trying to plot a route out of town and to get me back on route despite me ignoring it and trying to go up closed roads and into private estates. :lol: The track log for that hour looks like a child's first attempt at drawing!
Its very unlikely to be reception issues, we have both witnessed this behaviour when off route but, not every time. I admire your persistence and you must have the patience of a saint :D
