Locking device for the XT
Re: Locking device for the XT
I thought about making a tether, and never got around to it. Since getting the Zumo XT I've taken two week-long trips on my FJR - one to the Rocky Mountains in Colorado, another to the Smoky Mountains in Tennessee, for a total of just over 6,000 miles. The only issues I had was the damned thing locking up on 3 separate occasions, requiring me to reach behind and hold the button down for a half minute to reboot it. That sucked doing it while riding "The Dragon" (129 in TN). The power connection always worked, and the thing never popped off of the mount. As for theft prevention - I always just removed it and popped it into the Givi trunk in the back - much more secure than locking it to the mount (someone could, after all, just undo the RAM mount from the ball and it's theirs to keep).
Johnsondvr
- Has liked: 4 times
- Been liked: 4 times
Designed and had 3D Printed a lock clip - printing was PLA (FDM) 75% strength. M3 thumb screw or M3 domed bolt will self thread once screwed in and the release button on the Garmin mount does not move, even when the screw is not fully engaged. Not a perfect fit due the tight gap between the release button and the Zumo; it will also not work with the 3D Printed mount covers out there. Working well for me and just gives a little more piece of mind and security when stopped.
Link to the STL file if people want to edit / use https://www.tinkercad.com/things/kI1bb3MU3g3
- On Evotech Perfomance mount with M3 Thumb Screw
- A7325556-64AD-44A7-8308-11AF4BF7C32D.jpeg (324.57 KiB) Viewed 6589 times
- 20D96E9A-FADA-46B7-AC5B-B2D22FF604DD.jpeg (361.78 KiB) Viewed 6589 times
- A1FD34EC-3C78-4E59-98D1-D0AC3DB06B35.jpeg (278.64 KiB) Viewed 6589 times
- With M3 domed bolt
- ZumoXT Clip V2 - 1.jpg (398.18 KiB) Viewed 6589 times
Greg Fuess
Woody, did you post how you made your XT security lock? I would love to imitate that.woodyflyer wrote: Mon Oct 05, 2020 10:30 pm No happy about my XT not being very safe and secure while on the bike ,ie at petrol station /paying for the fuel, all it needs is a quick press of the mount clip and it's off and away by some vilian
To act as a deterrent and make it harder to be stolen, I decided to make a simple and cheap solution.
The idea is that the clip can't be pushed down to release the XT from the mount, plus I added a tether for extra security.
Took about a hour to make , a bit crude but effective , if anyone interested in how it's made let me know.
Woody
woodyflyer
- Been liked: 5 times
Hi John, hope you wont mind me asking but anychance you could make me 1of these. Has have no idea about 3D printing and dont know anybody else who does. Obviously will pay you for it and the P+P. TIAJohnsondvr wrote: Mon Oct 12, 2020 12:28 pm Designed and had 3D Printed a lock clip - printing was PLA (FDM) 75% strength. M3 thumb screw or M3 domed bolt will self thread once screwed in and the release button on the Garmin mount does not move, even when the screw is not fully engaged. Not a perfect fit due the tight gap between the release button and the Zumo; it will also not work with the 3D Printed mount covers out there. Working well for me and just gives a little more piece of mind and security when stopped.
- Has liked: 87 times
- Been liked: 248 times
Nice idea. I don't have a 3D printer, but I think I could make something similar with a bit of aluminum and a Dremel, maybe a little bigger to accommodate a small luggage lock.
Johnsondvr
Now installed one of these. Excellent bit of kit.
https://www.ebay.co.uk/itm/29503786920 ... media=COPY
- IMG_2022-6-26-215743.png (474.56 KiB) Viewed 5021 times
Welcome @motomushu .
Is that zip tie wrapped around the release catch to prevent it from being pressed down ?
