Page 7 of 26
Re: Introducing TripManager
Posted: Mon Apr 07, 2025 5:31 pm
by Raf
Hi! I downloaded the latest version of Trip Manager, 1.3.0.147. TripManager-main.zip. I can't find the setup exe. I can't install. Can you help me? Where is the .exe file? In the "Setup" folder there is only the setup.iss file.
Windows 10.
Thanks
Posted: Mon Apr 07, 2025 6:21 pm
by Peobody
The .zip file is the source code. The program installer is the setup_TripManager.exe file. Download and run that. It will install TripManager on your PC.
Posted: Mon Apr 07, 2025 6:42 pm
by Raf
I downloaded the file TripManager-main.zip. It's the only one I found. I can't find the file setup_TripManager.exe. Maybe I need to download another file? Can you send me a link?
Thanks
Posted: Mon Apr 07, 2025 6:55 pm
by Peobody
It's here: https://github.com/FrankBijnen/TripManager/releases
Edit: At the end of each version section is "Assets" which is where you'll find the files available for download.
Posted: Mon Apr 07, 2025 6:56 pm
by lkraus
Do not download a zip file.
Go here: https://github.com/FrankBijnen/TripManager/releases
Scroll down and click on setup_TripManager.exe :
Posted: Mon Apr 07, 2025 7:46 pm
by Raf
Found it!
Thanks @Peobody ,@ lkraus
Posted: Fri Apr 18, 2025 11:47 am
by JS_racer
installed the latest version, had the version before installed...
the latest version 1.3.0 displays tiny, like super small text, the box is tiny.. not sure what changed... the 1.2.0.125 didn't have that problem, it worked perfect in that regard..
not sure what i can do to change it, but its unusable for me..
shame, i was working with my xt and xt2 this morning, and updated the trip manager since I saw it was better with the xt2..
**had to go into high dpi settings, and change override to system... that seems to have gotten me back to seeing it**
Posted: Fri Apr 18, 2025 12:18 pm
by JS_racer
trying to rename xt trips, some worked...
lots giving errors..
copy failed and other errors...
also under poi, gpi format not supported error??
(not sure if normal, or rolling back would help, or just manually copy trips from the xt to xt2... )
Posted: Fri Apr 18, 2025 8:14 pm
by FrankB
JS_racer wrote: Fri Apr 18, 2025 11:47 am **had to go into high dpi settings, and change override to system... that seems to have gotten me back to seeing it**
Version 1.3 has HIGH-DPI support. It should look at a lot sharper when the Display scaling is set to a higher value than 100 %
The high dpi settings are the way to go, if you want the old behaviour
Posted: Fri Apr 18, 2025 8:17 pm
by FrankB
JS_racer wrote: Fri Apr 18, 2025 12:18 pm trying to rename xt trips, some worked...
Please provide more details, screenshot, a short description what you were doing, etc. if you want me to have a look.
JS_racer wrote: Fri Apr 18, 2025 12:18 pm or just manually copy trips from the xt to xt2... )
That will definitely not work. The format of the XT and XT2 is not compatible
