Distance to next point has disappeared!
Posted: Sun Nov 22, 2020 9:16 pm
by ianchapp
Used to be in the left of the top title bar. Any idea why this would be?
Yes, I'm navigating a route, and I've disabled other maps. And a full restart. I can get the info in the bottom-right customisable field, but would prefer that for ETA.
I'm trying to avoid a factory reset....
Re: Distance to next point has disappeared!
Posted: Thu Nov 26, 2020 12:50 pm
by nehpetsthegrey
I sympathise buddy. I am convinced that they are haunted and possessed by evil spirits. I have been trying to find out why the little compass symbol keeps disappearing on planned routes but not take me there stuff. Its all very frustrating.
Posted: Thu Nov 26, 2020 1:40 pm
by Oop North John
nehpetsthegrey wrote: ↑Thu Nov 26, 2020 12:50 pm
I'd noticed that at times, and the scale as well. Makes me think I'm losing the plot when I see it, then don't see it
Posted: Sat Nov 28, 2020 7:03 am
by Milu23771
The same happens to me too, during the simulation everything is perfect, when you travel with GPS on, the next turn, speed limit, warnings etc. disappear. This thing makes me desperate
Posted: Thu Apr 08, 2021 6:30 pm
by alain
I had the same problem, after a map and software update. solved by disabling all non-essential cards for the area
Posted: Fri Apr 09, 2021 5:47 am
by sussamb
Never a good idea to have more than one map selected if they cover the same area as it causes confusion like that described.
Posted: Fri Apr 09, 2021 1:05 pm
by V-Tom
alain wrote: ↑Thu Apr 08, 2021 6:30 pm
... solved by disabling all non-essential cards for the area
What does this mean?
Thanks,
Tom
Posted: Fri Apr 09, 2021 5:48 pm
by sussamb
Think he means maps ...
Posted: Fri Apr 09, 2021 6:59 pm
by alain
exact, merci sussamb
Posted: Sat Apr 10, 2021 6:30 am
by sussamb
Pas de problème
