Zumo XT Motorcycle Mount
Posted: Wed Jan 06, 2021 3:45 pm
by Kermit The Frog
Does the Motorcycle mount have a usb connection?
I'm getting one delivered on Friday, and I already have a 12v Socket installed on my motorbike, so it will be a lot easier just to plug the "cigarette lighter" in to the mount then to fiddle around with the car mount.
Re: Zumo XT Motorcycle Mount
Posted: Wed Jan 06, 2021 10:13 pm
by Stu
No it doesn't
Although you could easily wire power lead to whatever you need to to get it working
Posted: Thu Jan 07, 2021 11:57 am
by simoncrewe
Kermit The Frog wrote: ↑Wed Jan 06, 2021 3:45 pm
The MC mount just has 2 wires, red & black, as 'Stu' says put whatever termination or plug you need on the lead.
Posted: Wed Jan 13, 2021 9:42 am
by Kermit The Frog
Well I'm using the cigarette lighter connection plugged into the usb on the xt, but I wish they had put a usb connector on the cradle
Posted: Wed Jan 13, 2021 12:03 pm
by simoncrewe
I think they avoid a USB on motorcycle mounts as they attract dirt/moisture & have vibration issues. Hence most mounts are hard wired & encapsulated.
Posted: Wed Jan 13, 2021 4:22 pm
by me29
Kermit The Frog wrote: ↑Wed Jan 13, 2021 9:42 am
Have you had any problems with the vibration connecting with the USB cable to unit to charge while riding?
Posted: Wed Jan 13, 2021 5:21 pm
by Kermit The Frog
Only had it on for the first time this morning (Amazon were being really stupid delivering it), but I had no problems this morning. We'll see how it goes tonight
