Page 1 of 2
Basecamp Version
Posted: Sat Jan 23, 2021 1:48 pm
by khunpaul
Many of us have long resisted upgrading BC from 4.6.2 to 4.7.3 due to the Google Earth link.
Now that link has gone is there any other reason not to update? Or conversely is there any good reason to update?
Re: Basecamp Version
Posted: Sat Jan 23, 2021 2:51 pm
by sussamb
As 4.6.2 continues to work for me I'm not planning to update, my advice would be if it's working for you then there is little point in updating as later versions had nothing added to benefit users in my opinion, it was more to do with complying with GDPR than anything else although those with the XT should update as there were specific updates to cater for the XT. The full changelogs are here, such as they are:
https://www8.garmin.com/support/downloa ... sp?id=4435
Posted: Sat Jan 23, 2021 7:17 pm
by twowheelstom
I just checked my Basecamp Version to see how out of date I am and it's at 4.7.3 and I didn't even know it
Posted: Sun Jan 24, 2021 8:01 pm
by Oop North John
Is it possible to go to Google Earth from 4.7.3 please?
Posted: Sun Jan 24, 2021 9:31 pm
by sussamb
No, I'm afraid those days are now gone. The work around is to export your route as a .kml file and import that into GE.
Posted: Mon Jan 25, 2021 9:39 pm
by Stu
I have seen many people reference to GE and accessing it from Basecamp
I have never used that feature so what exactly does it do?
Posted: Mon Jan 25, 2021 9:46 pm
by sussamb
It shows the data in Google Earth, whether it's routes or tracks or waypoints. In GE you can look at the terrain and street view if you want to. Very convenient to check details of your routes etc.
Posted: Mon Jan 25, 2021 10:14 pm
by Stu
Right I see
I can see its uses then. I have used Google maps to plan a route before then exported it then imported to Basecamp but its a mess about
Posted: Thu Feb 08, 2024 7:48 pm
by khunpaul
I know this is a very old discussion.
However, I stuck to 4.6.2 until now but Garmin will not help me with an issue whereby I can no longer sign in to myGarmin through Basecamp unless I upgrade. I can sign in to Garmin Connect etc on a browser so I know the sign-in is valid.
Any opinions before I bite the bullet and upgrade.
Posted: Thu Feb 08, 2024 8:04 pm
by lkraus
khunpaul wrote: ↑Thu Feb 08, 2024 7:48 pm
Make an appointment with the dentist first?
It has been a very long time since there has actually been a Basecamp upgrade or bug fix. The last few versions only
removed features that were no longer supported. Google is mostly to blame for the loss of Google Earth support in Basecamp and other programs. Google kept making changes to their API and finally their access fees increased thousands of times from near nothing to a level unsupportable by free software.
