Page 1 of 2
No vocal instruction
Posted: Mon Feb 22, 2021 5:42 pm
by Andrew_XT
Hi to all
The Zumo stop the vocal instruction.
I check all the parameter, is the same i always used.
I try with the factory reset, and the problem still.
When i change same parameter, random, sometime the vocal instruction restart, but when i power off the device, after the restart, if i put a new destination it say only the first instruction and nothing else.
Sameone have any idea?
Thanks
Re: No vocal instruction
Posted: Mon Feb 22, 2021 6:37 pm
by Stu
could this be a headset problem?
Posted: Mon Feb 22, 2021 6:53 pm
by Andrew_XT
Stu wrote: Mon Feb 22, 2021 6:37 pm could this be a headset problem?
No, i also try with its headset
Posted: Mon Feb 22, 2021 10:57 pm
by Stu
What headset are you using?
Posted: Tue Feb 23, 2021 7:46 am
by Oop North John
Does it have the problem with and without a bluetooth headset, or only on one of these?
Posted: Tue Feb 23, 2021 5:43 pm
by Andrew_XT
I have the Midland Btx2 Pro
But..i try without the headset, with the Zumo speaker, and the problem is the same.
Posted: Wed Feb 24, 2021 10:04 am
by simoncrewe
Andrew_XT wrote: Tue Feb 23, 2021 5:43 pm I have the Midland Btx2 Pro
I have the same problem with my unit, using it in the car on its built in speaker. The unit says ; 'please drive to highlighted route' then nothing.
Has only just started doing this, so I will need to call Garmin.
Posted: Wed Feb 24, 2021 10:44 am
by simoncrewe
Andrew - I have just spoken to Garmin UK, they have asked me to send them a video of it happening, I get the impression that they know there is an issue.
I would suggest that you contact Garmin also.
Posted: Wed Feb 24, 2021 8:50 pm
by Andrew_XT
I also contacted Garmin mate
They ask to me to send to their teh Zumo for reparation.
Posted: Wed Feb 24, 2021 10:14 pm
by Andrew_XT
Same issue.
I remember another case in a Facebook group.
